ALIAS EDIT COMMAND
ALIAS EDIT COMMAND
craig
ALIAS EDIT COMMAND
craig
I am unable to get alias edit to work for changing my attacher commands.  Keep getting this error.
nathan.chapman
It seems you don't have permission to modify that file.  Not sure how you IT handles permission but if you navigate to the file location and go to it privileges give user full access. Now try to modify this file and it will work.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
markcalloway
Hi @craig
A requirement for most Autodesk software to function correctly is to have local admin rights on your computer.
Please see the following instructions from Microsoft:
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwif4ZmN-7bPAhVILcAKHUrXA...
Hopefully this will resolve your issue and prevent other permission related issues.
Let us know how you get on so other people with this issue can see how to fix it.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
john.vellek
Hi @craig,
Did adjusting the user permissions help to resolve this issue?
Please update the status of the problem in a post so I can help you if you still need it.
John Vellek
I have decided that the only way to edit the alias list is to go directly to the pgp file and then reinitialise it in autocad.  I have all the necessary permissions, and the alias edit sometimes works, but at other times I get the following error:
And reinit doesn't always work, either.  I changed the list so that D is Dtext, and DD is Dimstyle.  But autocad will not recognise DD:
And then I changed -B to be Block, and B to be -Block, but it didn't work.  When I went into the actual pgp file, it had put a series of ;;; in front of both B and -B, and hadn't changed them, either.  Can anyone tell me what I'm doing wrong?
Sorry, the first image was supposed to be:
Sorry - I'm new to this and I only found the edit button after I'd posted this one, but I can't delete it!
