Adding information to ductwork Bill of Materials
Good Morning
start by saying i,m a new user.
was hoping someone could talk me through adding fields to the Bill of materials options for ductwork within cadmep
in an ideal world, when i generate a BOM, i would like inlet size & outlet size to be displayed, Throat lengths & taper length etc to be displaced on a single page, without having to print part worksheets.
is this possible
cheers
Murray
nathan.chapman
Murray this is possible.  Within the product type Reports.  Create a  new report and add the field you need.  For example you would need End Size 1, End Size 2.  Here is some documentation on reports building. https://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/2...
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
