Add insulation to multiple pipes
busterbw
busterbw
How can I add insulation to multiple pipes at one time rather than one at a time? Using fabrication CADmep 2018
COD Scripts are the easiest way to do this. The script can run against anything you have selected.
MOatman
The change object(s) properties button or the MPROP command is another way to do it.  Select multiple pipes and fittings and hit enter.  It the dialog set the desired insulation settings and click OK.  Those settings will be applied to all the items.
busterbw
Thanks Millions!!
Yea...That would be easier. Sometimes I forget about the simpler approach.
