50x50mm cut outs falling into the plasma.
I have a requirement to cut out 100 or so 50x50mm parts for a job and was wondering if there is an option to create some sort of tab or way that would allow the parts to remain on the plasma.
I am assuming which i would need to trim off from the cutting sheet when complete which would be fine.
(Fabrication CAMduct2019)
dgreig1977
You could create a hole and import what you need into opus when developing.
LanceTSM
Use the "Stitch" Function either applied to the part in "Profiler" or applied to the Nested Sheet in "Manual Nest"
