3 x 3 x 3 x 2 pvc side inlet tee pvc.
RidgewayPlumbing
RidgewayPlumbing
I have no clue how to make this fitting work in fabrication cadmep any help is appreciated. Also none of my 1-1/2" pvc elbow is not showing but everything bigger is which is odd.
Replies (8)
david.dykes
Hi Andre
Not sure what fitting you are referring to, could you upload a dwg with the fitting on it?  I will be contacting you through the Support channel if you prefer to send it that way rather than on a public Forum.
RidgewayPlumbing
RidgewayPlumbing
Sorry its taking me so long to get back with you. Since I installed screen cast my autocad ribbon does not work anymore so trying to fix it then I will get back with you.
RidgewayPlumbing
Still did not get a solution to this fitting. Sending you link to ITM file of fitting let me know what is the out come.
https://www.dropbox.com/sh/knoiqquyeyn3l2e/AADA0NzRPEstY4ieBSoyvqcXa?dl=0
RidgewayPlumbing
It has been month and still no answer to my request. I can not believe that Autodesk would build a fitting for FabSide inlet tee.JPGrication CADMEP that does not work and place it in the software. this does not make any sense. I really need this part to work. I am currently doing a project that has almost a 100 of them and I can not do a report because it will fill that fitting.
RidgewayPlumbing
Still no solution on this Case 14521840
You do realize this isn't paid support.
RidgewayPlumbing
I am pretty aware that this is not paid support but this is also integrated with the Autodesk support system which i have a case opened.
