2D AutoCad Flat pattern to Camduct
sarizarey
sarizarey
Please i need help. I am trying to use the plazma cutting machine to cut any custom shape with the controller Burny. I just need to import autocad files to Camduct and then export the file to the machine. Any one can help!
nathan.chapman
You will have to generate a dxf file from cad then import in CAMduct.  Check out this link https://www.autodesk.com/autodesk-university/class/OPUS-DXF-Import-Flat-Pattern-Manipulation-2015
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
