Hello @clomedico
I understand that you are getting an error in Fabrication CADmep when using content manager. When you do, you get the error shown in the above screen shot.
I have tried to recreate this issue using our systems and I have not been able to replicate the issue you are experiencing.
In order to continue troubleshooting for you I would like to ask a couple of questions.
In addition to having Fabrication CADmep, do you also have ESTmep of CAMduct installed on your machine or in your office? If you do, do you have this same issue in those programs as well? Use link below if you are not sure how to download content in ESTmep, CAMduct or CADmep.
Is this issue happening to all of your CADmep machines or just yours?
Lastly when you get this error message can you please provide us with the "Details" of that error report? Clicking details may provide clues as to what is happening, with this information my team can try to advise what can be done if possible.
Can you please provide me with the details of that error report? If you do not feel comfortable posting that information here, you are welcome to send the file to me in private.
Thank you for your help and I look forward to your thoughts.
Hello @clomedico
I hope you are doing well and making lots of progress on your project.
I wanted to check in and see if you had a chance to review the suggestion from my last forum post, or if you have any additional questions for me?
If you found my previous post solved your problem, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
Donald,
We only have cadmep 2019 and it is only on my machine although the other machines are working off the same database. I also had a problem with a purge at one point. See post https://forums.autodesk.com/t5/fabrication-cadmep-forum/purge-database-bug/m-p/8154751#M3417 . below are the details from the error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Parameter is not valid.
at System.Drawing.Image.FromStream(Stream stream, Boolean useEmbeddedColorManagement, Boolean validateImageData)
at System.Windows.Forms.PictureBox.Load()
at System.Windows.Forms.PictureBox.set_ImageLocation(String value)
at webconnect.frmWebConnect.DataRepeater1_DrawItem(Object sender, DataRepeaterItemEventArgs e)
at Microsoft.VisualBasic.PowerPacks.DataRepeater.raise_DrawItem(Object sender, DataRepeaterItemEventArgs e)
at Microsoft.VisualBasic.PowerPacks.DataRepeater.UpdateItemAppearance(DataRepeaterItem item)
at Microsoft.VisualBasic.PowerPacks.DataRepeater.UpdateAppearance(Boolean updateExistingItemAppearance)
at Microsoft.VisualBasic.PowerPacks.DataRepeater.SetDataConnection()
at Microsoft.VisualBasic.PowerPacks.DataRepeater.set_DataSource(Object value)
at webconnect.frmWebConnect.btnSearch_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3163.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
webconnect
Assembly Version: 3.7.500.0
Win32 Version: 3.7.500.0
CodeBase: file:///C:/program%20files/autodesk/fabrication%202019/cadmep/WebConnect.exe
Assembly Version: 10.0.0.0
Win32 Version: 14.7.2558.0 built by: NET471REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.7.2558.0 built by: NET471REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.ServiceModel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.ServiceModel.Internals
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
SMDiagnostics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.ServiceModel.Channels
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
System.ServiceModel.Web
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.IdentityModel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Assembly Version: 12.0.0.0
Win32 Version: 12.0.21005.1
CodeBase: file:///C:/program%20files/autodesk/fabrication%202019/cadmep/Microsoft.VisualBasic.PowerPacks.DLL
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
System.Net.Http
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box
Hi @clomedico
Thank you for providing the information and screen shots above.
While we are doing some testing, can you please confirm if you have tried the following:
Can you confirm that you are using the most updated version of 2019 Fabrication CADmep? Follow the article below to determine if you are using the most up-to-date release of 2019 Fabrication CADmep.
If you are running the most up-to-date release can you try to Repair the program? See screenshot below for help
As mentioned as a work-around for your current issue, you can manually navigate to http://www.building3dcontent.com/ download your content there, and push this content into your working file.
When possible please let me know if my suggestions helped to resolve your issue, if you found my post solved your problem, please click on "Accept Solution" to help others with similar questions.
Hi @clomedico
