Revit 2017 extensions
Please tell me if these  extensions are availabe for Revit 2017:
Civil Structures
Composite Design
Excel Based Model Generation
Frame Generator
Timber Framing
I think they are no longer availables since the 2016 release.
Can you give me other products or extensions that do the same job?
5 Comments
gabriel_he
Status changed to: Archived
fran3_
Community Visitor
there was an answer to your question? urge those extensions , someone to help us .
martin.mcfadden
Here is the result of my research:
Revit Extensions for Autodesk Revit 2017
Mar 25, 2016
For Composite Design, Frame Generator, Timber Framing
Autodesk® Revit® 2017 Civil Structures Enhancements
Aug 19, 2016
Using these Bridge Modeling enhancements, you can generate bridges based on user-defined criteria. Users can define basic parameters of the geometry of a bridge including: a road profile, a deck, abutments, piers and railings. The road profile may also be imported from a LandXML format file.
Steel Connections for Autodesk® Revit® 2017 64-Bit
Apr 15, 2016
Use Steel Connections for Revit to view detailed structural connector geometry and to modify additional parameters in the Revit modeling environment.
These updates are availabe here:
I think Excel Based Model Generation is no longer availabe...
I want Civil Structure for Autodesk Revit 2017
munivelvit
Community Visitor
what shall i do to link Etabs to revit .
