When I try to open Fusion 360 on my windows computer it says I'm using an unsupported browser. I've tried two of the supported browsers, and a clean install from a supported browser but still no luck. How do I fix this?
Solved by dan.banach. Go to Solution.
Sorry for not getting back to you on this sooner. I tried your last two suggestions, but my settings already matched the suggestions in the articles. I'll be trying a different computer soon, as you suggested.
@dan.banach I tried opening Fusion 360 in the Chrome browser on a different computer, but still had the same error.
I also tried opening it locally on a different computer and still had no luck.
Hi @hehlaA3NXB
Thanks for trying on a different computer. I'll ask the support team to relook at your account. I'll keep you posted.
Thanks for your patience.
-Dan
Hi @hehlaA3NXB
I noticed that you're still using a Single-User Storage. Can you please try to update and update your projects to a Fusion Team and see if this helps? Click here for instructions on how to transfer Fusion 360 projects from Single User Storage to a Fusion Team.
-Dan
@dan.banach I've never been able to open Fusion 360, so I don't have any projects to move.
Hi @hehlaA3NXB
I'm going to send you a private message.
-Dan
Hi @hehlaA3NXB
The development team asked if you could try creating a Fusion Team via Fusion Onboarding site.
Let us know if you can create the team and then log into Fusion.
Keep us posted.
-Dan
Hi @hehlaA3NXB
Thanks for trying. The engineering team is looking at your account to identify the issue. I should know more shortly.
-Dan
Hi @hehlaA3NXB
Good news. The team found an issue with your profile. Can you please try to log into Fusion with your school email and let me know if you have success?
Thanks for your patience as we figured this out.
-Dan
Hi @hehlaA3NXB
Wanted to check-in and see if you were able to log into Fusion 360 and create a Fusion Team from your school email?
-Dan
Hello Dan, account works now! thank you so much for all your help through this issue. I'll mark it as resolved after I post this message. Happy new year!
