Zoom - bug
Zoom - bug
havlicek6TH3H
Zoom - bug
havlicek6TH3H
I´ve just found out when I maximally zoom out in schematics, the schematic dissapear when I zoom in it shows again. (Eagle 8.6.1 - Windows 10)
rachaelATWH4
Do the disappear or does it just zoom out really far so they become vanishingly small? My guess is there is some strange artefact in your design with a location somewhere a long way away at the extreme of the page size and this is causing the issue. Could you check with another design to see if it has the same issue?
Best Regards,
Rachael
havlicek6TH3H
I tried another design and it´s same. I tried even to zoom to fit and It looked ok - only schematic was on the screen. It´s not important bug.
https://youtu.be/qTJJJj1SyzQ
jorge_garcia
Hello @havlicek6TH3H,
I've created a bug report for this. Your right it's not a debilitating bug, but maybe resolving it resolves some other issues.
Thanks for the feedback.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
havlicek6TH3H
Hi, I just found out that same behavior is in board too. Just for clarification.
In board there is some specific behavior try to:
1) Select some parts
2) Hold left mouse and drag them
3) Still hold left mouse (draging parts) and zoom out for max
4) When the board dimishes move with the parts across whole work area - There are some strange graphic entities in workplace
