Hi @bvernham ,
I hope you're doing well. It would be good to have the schematic file to double check. Where did you get that X symbol from, did you make it? Is your component on GRID? If you can provide a file, that would be ideal but if not provide as much info as possible.
My hunch is that, the X symbol you created doesn't have a pin to define it's connection so it's not really connected to that pin(move the x if there's no net, there's no connection). In that case, you likely have that 3V3 pin set up as a power pin which automatically connects to other 3V3 pins.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
