Dear Team
I'm using EAGLE 9.4.2 on a MacBook Pro Mojave. I created a 2-layered PCB and gerber files using OSHPARK's DRC file.
https://docs.oshpark.com/design-tools/eagle/design-rules-files/
Surprisingly, the PCB manufacturer said the vias had a "solder mask opening"; the vias were exposed so that I can solder the via.
I don't want the vias to be exposed like this. What configuration I have to change to unexposed this?
Or do I have to set something from the CAMJob part?
Solved by jorge_garcia. Go to Solution.
Thanks, Jorge
Instead of 0mil, do you mean I should increase the value for the limit?
Deeply appreciate your help, Jorge.
One last question before closing; then can I simply set the limit value so high (like 100 mils) so that I don't have to worry about the vias getting exposed?
I'm quite surprised that the default value given to me is zero.
