Trying to have both GND and VCC pours for a 4-layer PCB
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
Hello, I am trying to make a 4-layer board, consisting of a top layer, bottom layer, a ground layer, and VCC layer (The names of the GND and VCC layers are arbitrary). I hope that I am correct in assuming this, but I was thinking that if I make a VCC layer, all components that connect to VCC will simply route to this layer automatically. If this is correctly implemented, I should not see any routing lines for VCC. However, when I run the autorouter, I am still seeing VCC routing connections running across the TOP and BOTTOM layers, which seems to indicate the components are not correctly connecting to the VCC layer. I would like your help, and I have included some images to explain my current configuration.
I have created each layer (as seen in the visible layers window), and for VCC and GND I have made polygons which cover the entire board.
For the VCC polygon I have the following settings:I would kindly appreciate your help! I'd be happy to include any additional information.
I am running the freemium educational version v9 of Eagle.
