EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Thicken via pad cross
2 REPLIES 2
398 Views, 2 Replies
I have changed the net class to increase the default width and auto-routed again, but these pads still seem to have some fairly thins connections to the ground plane. I've looked through many questions and posts about this but I cannot find what to change in this layout to thicken this pads.
Ideally I would like it to look like this:
Any help is greatly appreciated!
2 REPLIES 2
one-of-the-robs
This is a bit of an FAQ
Those "spokes" are created at the width specified for the polygon. Increase that and you'll get fatter ones. It also makes the edges of the polygon a bit softer and may prevent it passing through small gaps. You can get round that by defining overlapping polygons with the same name (net) but different widths.
in reply to: one-of-the-robs
Thanks a lot! That did the trick.
