Tcream layer not changing
r0782147
r0782147
I'm designing my PCB with some very small components so I would like the Tcream layer to not cover the entire pad.
This is so when I order my stencil and aply the paste I don't put to much on each pad.
I've already designed the board, when I change the Cream percentage in the DRC mask setting nothing changes.
Does anyone know how I can change this without having to draw the Tcream layer for each pad?
With kind regards
Sébastien
one-of-the-robs
Check what the manual or help says about cream masks but I'd suspect you won't see any effect of the percentage if you have both min and max set to zero!
