It would be convenient to be able to locally map specific ULP files into the Tools menu as user-mapped menu items.
Thanks!
While you can map ULPs to the command texts, I think being able to modify the standard set of tools would be great.
Then you could make tools have good defaults. Things like the dimension tool could default to the measures layer (instead of a routing layer or some other place it doesn't go).
I had planned to make an entirely custom toolbar that selects tools with default settings, but it's a lot of work to put that all together.
Best Regards,
Cameron
