Some library files are missing.
Hello Sir,
I have downloaded the Eagle Autodesk software trail version.
1. Some library files are missing. So after full subscription I would have full library file access.
2. Also after subscription email and phone option would be available for technical support..?
jorge_garcia
Hi @Anonymous,
I hope you're doing well. The libraries in the trial version are the same ones as in the premium version, so if there's a component you need that you don't see you'll have to make them yourself.
Once you have a subscription then you can take advantage of the schedule a Call option which allows you to schedule calls with support staff.
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
david.mellis
We've also stopped bundling some libraries with the application. They were either obsolete or had one only or two rarely used parts in them. They're still available for download in the library manager, but we wanted to reduce the clutter that we install by default. (We're also planning to add an option to never install the bundled libraries.)
