EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Simple copper pour gerber size is huge
4 REPLIES 4
rodney2FSB5
441 Views, 4 Replies
Why is what seems like a very simple copper pour (see attachement) on the bottom layer turn out to be nearly 24Mb in gerber output.  Needless to say when I panelize 6 of these the file is huge and prototype pcb houses only want to accept 10Mb files or less.
Is it something I've done wrong in creating them?  They are simple polygons.
4 REPLIES 4
rachaelATWH4
in reply to: rodney2FSB5
What size line width have you set for the polygons? EAGLE fills polygons by using lines set to the line width of the polygon. If you have it set to 0 then polygon fills will be huge.
Best Regards,
Rachael
rodney2FSB5
in reply to: rachaelATWH4
That could be it.  I'll give it a try!
rodney2FSB5
That did the trick!  Thanks for helping the noob.
rachaelATWH4
Glad it resolved your issue! We were all noobs once 🙂
