Resetting Eagle controls to default
scottH36AU
scottH36AU
For some reason my controls in Eagle are not standard. For instance I cannot right click after selecting a group to modify it, and I have to pan using the CTRL key. I do have a multi-button mouse, and so these should work. How do I reset Eagle to the default controls? I've tried uninstalling and reinstalling, but assume the settings are stored somewhere independently.
Scott
rachaelATWH4
I'm not sure what platform you are on but I assume it's Windows. In Linux/macOS there is a hidden file in the users home directory called .eaglerc where all these settings are stored. I assume there is a similar hidden file in the users home directory in Windows. If you have moved to 9.1 then this has now been buried in a version specific folder, I'm not sure 100% where, maybe App Data or some other hidden location? Anyway, wherever it is, removing (or renaming to keep as a backup) that file will cause EAGLE to generate a new one with default settings.
Best Regards,
Rachael
