problems with moving existing traces and trace widths.
Hi.
Apoligies in advance, english is not my native tongue.
I have run in to a couple of problems that is starting to annoy me when routing traces or moving exsisting traces on board lay out. I dont know it me that is doing something wrong(most likely), a design choice for which I cant figure the reason for, a bug of some sorts, or parhaps something that hopefully will get changed soon in a new version of Eagle.
If I as an example put down a trace with a witdh of 8mil and I want to change it later on to, lets say 10mil, I have to change each section of the trace individually either with the change button in the tool bar, or using the info button in the tool bar and use a scroll down menu. Is it really nor possible to change the width of an entire trace, lets say a Vcc trace, without all that work, or having to rip up the trace and re-route it with the correct width.
Second problem I have is that if I try to move a trace with the move command, the trace behaves like a trace that ignore obstacles. This also means, if I want to change which way I want a trace to go, I yet again have to use the rip-up function, and retrace the signal. Rather anoying if I as an example just want to use the move command to push a trace from one side of a drill hole to the other side. Is there a work around/function/command for this?
Any help or clarification would be much appreciated.
