Problem using ULP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I wrote a simple code in ULP to make a simple pcb using resistors and capacitors (I have generated the code by feeding the ULP documentation to Chatgpt). But the code is not running. It will be great if someone debug the code for me.
The code is like this:
#usage "This ULP creates a simple PCB layout with basic elements."
board(B) {
// Set grid and dimensions
B.grid.on = 1;
B.grid.unit = GRID_UNIT_MM; // Set unit to millimeters
B.grid.distance = 0.1; // Grid distance 0.1 mm
// Add a few elements (Resistor and Capacitor)
B.elements(E) {
if (E.name == "") { // Add resistor if element slot is empty
E.package = "R-EU_0207"; // Add a resistor package (make sure this exists in the library)
E.name = "R1"; // Assign a name to the element
E.x = 10; // X coordinate of the element in mm
E.y = 15; // Y coordinate of the element in mm
if (E.name == "") { // Add capacitor if element slot is empty
E.package = "C-EU0603"; // Add a capacitor package (make sure this exists in the library)
E.name = "C1"; // Assign a name to the element
E.x = 20; // X coordinate of the element in mm
// Create a signal for wiring
B.signals(S) {
if (S.name == "") { // Create a new signal for wiring
S.name = "Net1";
S.wires(W) {
W.x1 = 10; W.y1 = 15; // Start point of wire
W.x2 = 20; W.y2 = 15; // End point of wire
W.width = 0.5; // Wire width in mm
W.layer = LAYER_TOP; // Place the wire on the top layer
printf("Simple PCB layout generated with components and basic wiring.");
exit(0); // Exit ULP
I have also attached the documentation that I have used.
