print to pdf changes colors
EagleCC
EagleCC
I have 2 designs
On the first one I managed to set white color to the Layer 49 Reference
The the top layer to a green color
When I print to PDF, the green becomes a light grey and the white black. (So my text is black)
However, on the second drawing with the exact same parameters on layer colors (I actually exported the ULP from 1st file to second one and ran SCR) but then when I sent to print pdf, the green becomes light gray BUT the white color becomes a light shade of gray so I cant see the text
Thanks for the help!
jorge_garcia
Hi @EagleCC
See my response here:
https://forums.autodesk.com/t5/eagle-forum/pcb-printing-colors/m-p/10972221#M36737
Let me know if you continue to run into problems
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
EagleCC
Jorge,
Thank you for taking the time to answer my post
I actually took the "good file" and ran the ULP to extract the palette
Then I took the "bad" file and run the SCR of the palette from file1
However, this didn't work
In short: I need the white color in Eagle to be sent to pdf as black
