I'm attempting to move from Eagle 9.x to Fusion but I'm having an issue related to a difference in the way Fusion renders polygons vs. Eagle 9 (or at least I think so). I'm using the Buzzard Label Generator, which is a python library that takes plain text and converts it into an object to place into Eagle. Here is what the text object on layer 21 (silk) looked like previously (top) and now (bottom):
I contacted the developer of the tool and he seems to think its related to the way that Eagle rendered polygons previously by determining what to fill based on the "direction of the nested shapes". He suspects that Fusion has changed this behavior.
In comparing the same board file silk objects in their raw XML format, I can't conclude anything except that there are much more lines in the BRD file dealing with the individual silk object before I import it into Fusion then after. Here is a "before-an-import" image:
And an "after-import" image:
Any insight into what has changed would be very helpful for me and to the developer of that tool. Is there by the off chance a workaround?
