Plated-through square custom forms
Halo, I have very similar problem to a question posted in other thread about an oval plated hole:
as what i need is a plated-through square, and in a close future other custom forms done in EAGLE.
I have usually made this as follows:
- Square via with smallest hole of the pcb manufacturer (0.35mm)
- Milling 0.01mm on layer 46 close to the external of the via (photo attached)
But should be a better way for a plated thru-hole square, right?
Pcb´s manufacturers after a few mails and up to a week, agree to do this forms but with lots of confusion,
but the minimum hole on pad confuses them and slows a lot the pcb manufacturing process.
Does making a library with 2 pad (top/bottom) and a milling, makes a platting connection?
I finally would like to learn to do it on a proper library, establishing proper clearances by using the power of eagle.
I have good experience on ealge and eagle library making for HF/RF.
How would you suggest to do this?
Big thanks in advance!
