PCB trace finish material
NikosAntoniou
NikosAntoniou
Dear all,
I want to know whether or not there is any option in Eagle to specify the trace finish material. I design a board that will carry RF signals and some of the traces as well as the SMA connectors pads needs to be gold plated.
In case that Eagle don't support that feature, how to I specify this detail to my manufacturer?
Thanks in advance
AutodeskEagleCad
The entire board will need to be gold plated. Many board houses can do this for you, but not all.
I am not affiliated with Autodesk. I am a subscriber to the professional edition of Eagle and I've used Autodesk products for >20 years. The username displayed is the first half of the e-mail address I use to communicate with this forum, wherein I use (forum.name@mydomain.com) so it lands in my catch-all and I can pinpoint any entity who sells me out to the spam world. 🙂 I hope my contributions benefit others as much as the contributions of others have benefited me. Good luck with your project!
NikosAntoniou
Thank you for your reply!!
So I can use ENIG finish and for each pad or trace I want to be gold plated I draw a polygon in either tstop or bstop layer?
Andreas.Schimke
Hello @NikosAntoniou,
first of all you should check with your board house if they can produce a pcb with two different surface options.
The generation of data for the board house is easy (as usual you have several options, I will explain one of them):
1. Generate a new layer with the name of your surface finish option
2. Mark with a polygon, or rectangle or... the area which should have a different surface finish
3. Generate a separate gerber file for this layer
4. Explain your board house the meaning of the gerber file from step 3
Andreas
AutodeskEagleCad
I would just make everything gold plated.
It's popular and not as expensive as you'd think. But not every board house can do it.
