I made a new wirepad with a bigger diameter pad (0.165") and hole (0.065"). When I do a drill drawing for the final PCB, those pads only show a 55 mil hole size, not 65 mils. What am I doing wrong?
Solved by danYL62T. Go to Solution.
Hi Dan,
I hope you're doing well. When you make changes to the drills, you have to delete everything that the previous run of the drillegend-stack.ulp did. Otherwise it won't run because it sees features already there. It pretty simple just delete everything on the drill layers created by the ULP. Keep in mind that in order to delete the drill table itself you'll have to leave tOrigins on and click near the top left corner of the table since that is where it's grab point is.
After you have removed this old data, then run the drillegend-stack.ulp again and you should see an updated drill table. As a recomendation, this little process makes it worthwhile to leave generating the drill table as one of the last steps of your desing process.
Please click accept as solution if my post fully resolves or you issue, or reply with additional details if the problem persists.
Let me know if there's anything else I can do or you.
Best Regards,
