Let's go back to here:
"Now the coil shows up when I insert the component and NEXT comes (one by one by clicking) the switches !!!
Too on each pin is shown a number from 1 .. 10 and the only place I can see these row of numbers is tha PAD number in the library.
Now remains:
1) How can I get the WHOLE component ( coil AND switches) the show up when inserted ?
2) Get rid of these PAD numbers 1 .. 10 - I have my own numbers already set DIFFERENT from 1 .. 10 ?
(It's the black numbers 1 .. 10 in the attachment I want to hide !)"
In the library in Symbol editor you can rename those pins using the Name command.
You can also determine whether the pins display those number by Right Click the pin, Properties, Visible.
As to the pins themselves showing up, there are different styles of pins which will display differently, and maybe that's where we're lost (in understanding each other). If you use the Pin command (to add a new pin) a horizontal toolbar opens up towards the top of the screen. You can choose from options along the lines of Point, Pin, Short, Medium, Long and many other options. The option you choose will determine what you see in your schematic.
Are we making progress?
And FYI, I don't work for Autodesk. I have this screen name because that's the e-mail address I used to sign up as I do on most sites so any spam can be dealt with and identified as to the source (you need a catch-all on your mail server to do it; it works great).
I am not affiliated with Autodesk. I am a subscriber to the professional edition of Eagle and I've used Autodesk products for >20 years. The username displayed is the first half of the e-mail address I use to communicate with this forum, wherein I use (
[email protected]) so it lands in my catch-all and I can pinpoint any entity who sells me out to the spam world.
🙂 I hope my contributions benefit others as much as the contributions of others have benefited me. Good luck with your project!
