in short, what is the best way to update my current design?
I am a grad student trying to finish my thesis which relied heavily on generating images and diagrams of my pcb design. I am building a full device, complete with case design, so I have been using the ecadio script to build 3d models I can then use in Fusion 360.
However, now that Autodesk is trying to integrate Eagle and Fusion (I think is great by the way), I am stuck not being able to update my models.
I have some last minute changes that I am trying to reflect for my thesis, but it seems support for the ecadio script is down. Therefore I am forced to sync my pcb with Fusion in the way Autodesk would like. Not convenient, but it shouldn't be that big of a deal.... Instead, I am facing several road blocks I am hoping someone can help with.
I currently have a pcb full of devices from random libraries which do not contain accurate 3D models (generic blocks). I need to get them to reflect what the components actually look like. I have all 3D models thanks to previous downloads through ecadio, but I need to map this geometry to the devices in the library.
I have gone about this two different ways and run into issues.
1) I create a managed library from the small custom library I use for the unique / non-standard parts in my pcb deign. I have successfully uploaded STEP files and linked them to components that were in the library when I converted it to a managed library.
The real issue comes in when trying to produce 3D models for the other components not located in my custom library. For instance, I am using two different Atmel microcontrollers with the TQFP-32 package. The 3D version of this online is a block, but I have a STEP file that is accurate. I tried importing the devices into my custom lib through the Eagle software, but anything I add through Eagle (devices, models, etc) does not get reflected on the web. I cannot find a way to update / refresh the web view, nor a way to add devices to the lib via the web interface. Additionally, the only way to add a custom STEP file is to an existing device via web interface. Therefore, I reached a dead end.
2) The second method is to convert every library I use in my design to managed, which seems daunting. Of course, there are several components in each library I do not use, so converting many large libs to only update a couple components seems unnecessary. However, for the sake of finishing my thesis, I am willing. When trying this method, I converted the Atmel lib so I could update the microcontrollers I use. Indeed the conversion took several minutes, but then trying to view it on the web caused the loading of the interface to fail (took too long).
Does anyone have insight here? I am hoping I am doing all of this incorrectly, or I am missing some steps in configuring the link between Fusion and Eagle because this is difficult
