Naming nets as "not" pins
Sorry, excuse my terminology. If I have a pin such as /WE or /CAS, /RAS etc, how do I name a net so that it matches the pin symbol name when the component has a bar right across the top?
For example, if the component looks like this:
osjC8t6
I want to connect the above pins on an SDRAM chip to some header pins. What would I enter in the below naming dialog box to match the IC1_WE shown above?
GbEuMeo
decee.server
You forgot to call it IC1_!WE
Well.. I didn't forget to use '!'.. I simply didn't know 🙂 Great solution - thank you!
