Moving parts in fusion 360 does not alow to select any component
mjenkins5720
mjenkins5720
Has anyone used the move parts in fusion 360?
After several sequences and PCBs, none of them allow you to move individual components.
Can any offer any suggestions
jorge_garcia
Hello @mjenkins5720,
I hope you're doing well. Once you have the PCB on the timeline in Fusion360, right click the PCB on the timeline at the bottom and click Edit. The menu at the top will change and you'll see the option to move components click it and you should then be able to move the components around as you see fit.
Please let me know if you are seeing something other than this.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
mjenkins5720
Hello Jorge
Thank you for the reply, i never thought to look in the timeline for edit.
Also as i reshaped my PCB, some of my parts fell outside the 160mm area. So i guess the shape is not as important as the area.
Again thanks for the reply.
