mountsmd.ulp generates empty file
adrian.ochotny
adrian.ochotny
Community Visitor
Community Visitor
Hi
I want to generate coordinates for Pick&Place machine. I've learned that I have to use mountsmd.ulp or centroid-screamingcircuits-smd.ulp, but generated files don't contain any coordinates. Files from mountsmd are just empty, from centroid-screamingcircuits-smd.ulp there is only header. What should I do? Is there any configuration needed? I'm using example of USB charger circuit from http://eagle.autodesk.com/eagle/reference-designs
best regards
Adrian
marcoJTHQQ
In the design you are referring to no SMD components are used, only through hole. No SMDs, no SMD coordinates.
