Microvias will not place
- Mute
- Permalink
- Report
I am currently using full featured Fusion 360 with Eagle. I have an MCU component (nRF 5340) that requires microvia placement to connect pins. In the current version of eagle, microvias don't seem to be working, though I have enabled them. To recap my attemps:
- I am using a 4 layer board, so microvia checks should acknowledge this.
- I have set min. microvia to be smaller than min drill size to enable microvias. Currently micro drill size is 0.35mm, min microvia is 0.1 mm (though smaller and slightly larger sizes also do not work).
- When attempting a microvia, I click on the pad with the router enabled, draw the trace out a short distance, press spacebar to move to the nearest layer, and then move the cursor back over the pad, which should enable the microvia, but nothing happens. Potentially notable, when doing standard vias, the trace doesn't automatically connect to the via, which is newer behaviour for me. This point may not be relevant to microvias, but thought I would mention it.
It seems like I'm doing everything correctly, so I must be missing something. Any assistance and/or workarounds would be greatly welcomed.
