Hi, Could someone explain where I should enter my Serial number/ Key, so that I can use my monthly subscription. Going to "manage.autodesk.com", shows that I have a Serial # and product key. I read that a window was suppose to show up when I downloaded Eagle asking if I wanted to enter the info, but since I just wanted to try the software, I chose not to. I ended up uninstalling it and reinstalling it to hopefully that license link again, but nothing. It hasn't automatically filled in the licence#, because when I open Eagle, it is the same as before (2 layers, small board area). Any ideas? Thanks, John
Hi @4johnlori,
I hope you're doing well. If you are using Autodesk EAGLE then all you have to do is login to your Autodesk account through EAGLE. When you first start Autodesk EAGLE, you should get a login screen.
If you are using one of the older versions of EAGLE (V7 or prior) then the Autodesk Entitlement doesn't apply and you have to get your old licensing credentials(key file and installation code).
If you could specify what version of EAGLE you are trying to use, I think that will clear things up.
Let me know if there's anything else I can do for you.
Best Regards,
