Keeping copper fill away from certain sections of the middle layers
mgonchar
mgonchar
I need to keep the copper fill away from some sections of the middle layers. Please look at the attached picture. The area in yellow is copper fill on the second layer. I would cut from this copper fill a section that I drew in back in the top left corner of the picture. This cut is needed to reduce the capacitance of the trace that runs on the top layer and over the section that would like to cut from the copper fill.
Is there a way to make such a cut without having to re-shape the original copper fill polygon?
jorge_garcia
Hello @mgonchar,
I hope you're doing well. The easiest way to do this is to use cutout polygons to draw in voids. You'll find that under the polygon menu.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
mgonchar
That worked. Thanks.
