Thanks for you post! In fact there are LOTS of tutorials and such, so I'll try and hone in on some that should help you come up to speed quickly!
Firstly, in the way of "print" content, you'll find a tutorial in the installation directory which walks you thru much of the basics of using EAGLE. To find it, open the control panel in EAGLE (Window->Control Panel if you're in schematic or PCB) and there you'll find the tutorials listed along the left, in the Documentation section of the folder browser...along with a manual which is kept up to date between releases:
WRT to video content, our support teams do webinars regularly and produce regular videos, then post the recorded content on Youtube making it accessible to the largest audience (rather than placing this content behind a login or on a private website). The *official* Autodesk EAGLE youtube account includes videos covering everything from getting started thru to advanced concepts like simulation, high speed design, and more. You can find that page here:
https://www.youtube.com/channel/UCjPWeOcXkMIOA_bd4LbivGg
You can also find a step by step getting started video located on the Autodesk website here:
http://eagle.autodesk.com/eagle/product-tour
...This video will guide you thru much of the EAGLE SW and should help you come up to speed quickly!
You can find content generated both by Autodesk and the community located on the Autodesk website here:
http://eagle.autodesk.com/eagle/documentation
And you can find some great community tutorials on the Sparkfun, Seeedstudio, Adafruit and Element 14 websites & here's an example on Sparkfun:
Installation and Getting Started --
https://learn.sparkfun.com/tutorials/how-to-install-and-setup-eagle
Using Schematic --
https://learn.sparkfun.com/tutorials/using-eagle-schematic
Using PCB --
https://learn.sparkfun.com/tutorials/using-eagle-board-layout
There are also regular webinars running for EAGLE and I would encourage you to check them out! Join the email list for EAGLE and you'll hear about webinars, etc. You can find the blog and sign up for comms from Autodesk at our website:
Finally, let me encourage you to ask questions here! We do our best to reply to everything and anything and the entire development team, support team and upper management team is here and accounted for. We all participate and want you to be successful using the product. It can take a little time to come up to speed but we'll help you with the learning curve, for sure! And our community is second to none! So dont be surprised if you get responses from anyone and everyone.
Hope that helps!
Best regards,
Matt Berggren
Director - Autodesk EAGLE, Tinkercad, Fusion
Autodesk.
