Incompatibility with Acer Laptop
jkwsrw
Observer Observer
jkwsrw
Observer
Observer
Eagle will not launch successfully on ACER laptop.
ACER Model Spin SP111-31
Celeron CPU N3350 @ 1.10 GHz
Windows 10 64-bit Operating System
4GB System Memory
Error Message:
eagle.exe has stopped working
Aproblem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
        Close Program
Please Advise.
rachaelATWH4
It's possibly a graphics driver issue. Are there any driver updates available?
You can try starting EAGLE with the batch file for running with Software OpenGL which is available somewhere in the install directory (not sure where as I don't run Windows), using that often fixes issues like this.
Best Regards,
Rachael
