"DROPLET inlets and exits would be welcome..."
I'm not sure if you mean "teardrops"? There is a ULP included for this.
Once applied, however, they are not easy to move so I apply the script after the board layout is finished. Save a version if you need to make changes.
I have looked at the impedance numbers from at least four different impedance calc software sources, they all come up with different numbers fo CPW-ground.
IPC standards are the base for the excellent Saturn PCB. (Linux version does not runs under Wine as intended).
Mantaro and HughesCircuits comes up with very different results for "asymmetric stripline", in my case 49.7 ohms vs. 67.9 Ohms, respectively. I think the latter is really off.
What is not included in these calculator inputs is the effect of soldermask. Most likely, the programs assume no soldermask, but that is a guess.
One way around this would be to use "Embedded Microstrip" calculation, and place the trace ~ 2 mil under the surface. This would assume the same dielectic constant for both the soldermask and the board material.
For very low loss/high power/high frequency work I would leave the trace, and its sides if CPW, bare.
Constant impedance bends would typically imply mitered corners. With differential pairs this gets complicated. If the radius of a bend is more than three times its width, impedance should be constant.
This would be the easiest way, if you don't have room for this then some stronger medicine is needed.
