IDF Export problems
I am trying to export an IDF file from my PCB layout in Eagle 9.3.1. I keep getting this error dialog:
"An error was found in your board outline that cannot be automatically repaired. Outlines must be enclosed loops. Defects will be shown in layer 113 with red circles."
The board outline IS a closed loop made from lines and arcs in layer 20 as it should (board outline is drawn manually, not part of a package), but I still keep getting the error.
The layer 113 has one red circle, but I can't see any problem with the object (typically a point between an arc and a line or an arc) it points to... If I remove the arc that is allegedly problematic and replace it with a straight line the on the next IDF export attempt I get the same error in a different place.
Any ideas what is the problem?
