I can't make a through hole on a pad.
kntkimura76
kntkimura76
I'm a very new bee eagle user.
I can't make a through hole on a pad since I downloaded Eagle.
My situation is like that.
Yura.Ivanov.VLuki
Отверстия надо создавать в сигнальных слоях (1 TOP), (21_tPlace) - слой шелкографии.
Openings should be created in alarm layers (1 TOP), (21_tPlace) - a silk-screen printing layer.
Good luck.
jorge_garcia
Hi @kntkimura76,
I hope you're doing well. Go to Options > Set > Misc. Tab and make sure Display drills is checked. That should solve it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
kntkimura76
Thank you very much for your answer.
Thanks for your advise,  I have got it well !!
kntkimura76
Thank you for your answer.
kntkimura76
Thank you very much.
