How to view the actual drill size of a TH-Pad directly on PCB
10679488g
10679488g
Graph 1
Hello everyone, i would like to ask how to view the actual drill size of a TH-Pad (Pad and its relative pin are circled by pink circles on Graph 1) directly on PCB?
It is more efficient and faster to view it without opening relative library and drill size Notation.
However, i don't know how to do it directly. I would be glad if you have any answer(s) for me. I am using Eagle v5.10.
Thanks a lot.
jorge_garcia
Hi @10679488g,
I hope you're doing well. Unfortunately, v5.10 doesn't have an easy way to do this. Later versions of EAGLE and now Fusion implemented the Design Manager which would allow you to drill down into the component and see the drill size.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
10679488g
Thanks a lot. Would you pls tell me more about the complex method
jorge_garcia
Hello @10679488g ,
The complex method is what you have been doing which is going into the library and looking at the properties of the pad there.
Best Regards,
Jorge Garcia
