How to uninstall EAGLE from Ubuntu 20.04
Hello Autodesk EAGLE,
some time ago I had installed EAGLE for students to use it for one university project that required us to use it. But after all the time now I want to remove it and the license probably expired some time ago anyways. I found no instructions and no actual help within a reasonable amount of time searching. It is unavailable with "apt" and unavailable in the software center. I found no uninstaller included.
I would be thankful if you can help me 😉 .
jorge_garcia
Hi @Anonymous ,
I hope you're doing well. To uninstall EAGLE, all you have to do is delete it's installation folder wherever it is on your system. Additionally in your home directory there's a hidden .eagle folder, you can delete it also.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thank you for your answer Jorge!
