How to hide or remove default 3d object in managed library
Hi I made my library a manged one. This added default 3d objects. I cannot delete the 3d object for one part as it says it is in use. I have tried editing the default object.
When i edit it I have tried the following things to no avail.
- Remove 3D model. The model is removed but the showing the 3D design in Fusion this default model still shows up.
- Move the default shape below the surface of the PCB effectively hiding it. This also does not work as the default model again shows in Fusion
- Made the 3d object as small as possible .01mm and i still the default model rendered in Fusion.
What is going on here?
What can i do to remove/hide/shrink this model?
