how to edit existing part to create my own in eagle 9.3.0
I am new here also new for a eagle 9.3.0. I want to learn how to modify existing component and create new component
For example there is package for 4n35  but I am learning how to create library for MOC32021 from 4N35
ultimate aim to learn to modify exciting library to create new library in 9.3.0
Gajya
jorge_garcia
Hello @Anonymous,
I hope you're have an excellent day. Welcome to our forums. The recommended approach is to copy the component of interest to your personal library and make changes there, leaving the original unaltered. This is easy to do.
1. In the EAGLE control panel > File > New > Library
2. In the table of contents view at the bottom of each of the 4 columns you can add a new device/footprint/3Dpackage/Symbol.
3. Click the add button for the type of item you want to create.
4. In the dialog that pops up click import... This will allow you to bring in assets from other libraries.
5. Find the component you want and click OK.
The component has now been copied to your library and you can modify it as you wish.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thanks for sharing the information. I have followed the all steps and I got this windows How to get modified parts
Sorry for reactivating this post but have you seen the message after your response? I am in the same situation: after following your procedure it is still impossible to modify anything.
doreen_holley
How do you create a custom part not found in a library?
jorge_garcia
Hello @doreen_holley,
I hope this message finds you well. If you are still using EAGLE then the best tutorial for part creation I can recommend is chp 8 of the EAGLE manual. You can also check out the EAGLE youtube channel.
Best Regards,
Jorge Garcia
