How to draw a filled, rounded rectangle in Eagle
12:30 AM
My task sounds quite simple: draw a filled square of 0.25 mm with rounded corners (where r = 0.05 mm) to denote solder paste (i.e. on layer tCream).
Unfortunately, I haven't figured it out yet how to do this easily. I'd tried
- using rectangle but its roundness is not adjustable.
- using circle but its straight is not adjustable.
- using polygon with miter, radius equal to my desired size, and L or S shaped wire bend but micro-adjusting all of its 8 line segments to their exact places is extremely inconvenient since as you move just one segment, the whole polygon blows up. But, at least, I know how to draw spaceship Enterprise.
- creating straight-edged polygon and then using the Split command on their lines. This way the split command result is barely visible and prone to error since I operate with mouse.
What do you think is the easiest way to create a rectangle with rounded corners?
Just to be easier to imagine, I have to draw the red squares:
