How to do PCB trace characteristic impedance correctly?
grahamUTKMN
grahamUTKMN
In the past I've asked the board manufacturer to adjust certain traces to get the correct impedance characteristic, but is there a correct way to do it in Eagle?
G
m.neujahr_at_moe
Hello @grahamUTKMN,
in Eagle you can do it by defining "Netclasses":
First define the desired wire-width depending on your layer-stack.
Then you have to change the net-class of the net to the new net-class (right-click on net -> properties) and after that you can route the trace
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
grahamUTKMN
But how does that calculate the impedance?
G
m.neujahr_at_moe
Hello @grahamUTKMN,
the calculation has to be done by your own:
jorge_garcia
Just to add to what @m.neujahr_at_moe mentioned.
I've used the saturn pcb toolkit (google it) to do these types of impedance calculations.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
