I have a schematic that has multiple repeated components, and they all need to have attributes added or updated. For example, I need to add the same manufacturer, manufacturer's part number and standard description to a dozen resistors on a single page. then I need to repeat for a dozen different resistors, capacitors, ICS and miscellaneous other parts.
Is there a way to do this without opening the attribute for each individual resistor and adding the manufacturer, manufacturer's part number and standard description as new attributes? It seems like there should be an easier way to do this, even if it's just a command-line that I can enter for each attribute and just click on the parts rather than opening the attribute, clicking "new," typing the attribute name and pasting the attribute value to every part. (Just describing the procedure is exhausting, imagine having do do it for hundreds of components)
There's an ULP that claims to do update attributes for a group of components (attrib-add), but it doesn't appear to do anything but give me an error saying nothing is selected even when parts are clearly selected.
Any assistance on, for example, how to use the attribute command line would be appreciated. The F1 description of how to use attribute is less helpful than it could be.
