EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
EAGLE Forum
Post 1 of 4
Accepted Solution
Highlight select holes before exporting Gerbers?
65 Views, 3 Replies
03-14-2017 04:40 PM
Hello all, I am testing my own PCB so I'm drilling holes of interest onto a separate test board/fixture. I'm using the PCB-GCode ULP (http://pcbgcode.org/) in order to export Gerbers and drill files directly from Eagle. Since I'm only interested in testing a few holes scattered throughout the board, is it possible to select specific holes to export using the ULP instead of exporting every hole and via? The holes of interest are of both the standalone and part-of-a-through-hole-connector variety.
Hi mma08,
Thanks for the additional information. From the board editor you can't select component pads individually and there's no current way to have the ULP only grab certain specific pads.
It might be easier to generate the Gcode and then remove the extra holes from the exported Gcode, I don't see an easy way to exclude them within EAGLE.
Let me know if there's anything else I can do for you.
Best Regards,
Post 2 of 4
Re: Highlight select holes before exporting Gerbers?
03-15-2017 09:53 AM in reply to: mma08
Hello mma08,
I hope you're doing well today. There isn't an easy solution for this right now. The best thing to do would be to copy the outlines of those specific holes to another layer and then export that layer on it's own. That would give you are gerber with only the specific holes of interest.
That would be the best solution at this moment.
Also please accept as solution if this post resolves your issue.
Best Regards,
Jorge Garcia
Product Support Specialist for EAGLE
Post 3 of 4
03-15-2017 03:24 PM in reply to: jorge.garcia
Thanks for the quick reply, Jorge. However, I can't select the holes because I don't have the original design file--a PCAD ASCII.brd file was exported from Altium and given to me to use. It seems as though Eagle auto-generated a library when opening .brd file, but the schematic contains no components.
I can display the pads associated with specific components by typing in 'show [component/net name]' However, I can't seem to move or control those items in any way. Do you know of a workaround? Also, are there particular layers I would choose to export?
Attached is an example highlighting of the top-left connector.
Post 4 of 4
03-16-2017 11:15 AM in reply to: mma08
Hi mma08,
Best Regards,
Jorge Garcia
Post to the Community
New Post
