Help with Via In Pads
I an new to Eagle and having issues with via-in-pads. I placed the via in the pad of my SMD component. The pad is connected to my +DC net on the top side of the board. I have placed a polygon with the same net name on the bottom side of the board. To connect the +DC pad, I placed a via in the pad of SMD component. I expected it to automatically detect that I was placing a via-in-pad and connect the via to the appropriate net by default. This did not happen; it named the via with the next available net name that was unused. I manually changed the via name to the the appropriate net name but when running the DRC it shows that it is still not connected.
Is there a way to set it up so the net names becomes that of the pad/polygon when placed in one? How do I connect this pad/via/polygon correctly using a via-in-pad?
Your help is appreciated.
