Going to Eagle 9.1.0 on screen menus and Dialog boxes got much bigger
r_morrell
Observer Observer
r_morrell
Observer
Observer
When I went to Eagle 9.1.0 on Windows the on screen menus went much bigger , taking more screen space and the dialog boxes - for example when looking at layer got much bigger - all taking much more screen real estate
r_morrell
Observer
Observer
eagle 9.0.1eagle 9.0.1eagle 9.1.0eagle 9.1.0
HelenChen-AutodeskQA
So sorry for any inconvenience, r_morrell.
We are investigating this issue and trying to resolve it.
Are you in a 4k screen? Windows build?
Helen
Helen Chen
Principle QA for AutoCAD Windows
r_morrell
Observer
Observer
It is a 1920 X 1080 Dell.
Win 10.
I checked and this is red-face dept
I found it had a 175%  scale set
I unset that
Then window set it to 125 % scale
which solved the problem - see below
the top image has the 9.1.0
and the bottom the 9.0.1
while the menus are bigger  it does not hog the screen real estate , also while not shown here the dialog boxex are now manageable with the OK button on the screen and not taking too much space
thanks for investigating - you questions sent me on the right path
Thank you r_morrel. So far we found if you lower the resolution of the screen display, it might help as a "temp solutoin", anyway it's indeed need to be fixed.
FYI - Similar user post could be found here: https://forums.autodesk.com/t5/eagle-forum/rendering-is-very-bad-in-eagle-9-1-by-default-poor-hdpi-s...
Sorry for any inconvenience.
Helen
Helen Chen
Dear all,
In Eagle 9.1.2, we allow user to enable or disable the high DPI scaling and auto screen scale factor. You could find  the 2 new options in the User interface dialog.
If you have the display issue ago in monitor with high DPI, please deselect the 2 options and relaunch Eagle to have a try.
Hope it works for you.
Please feel free to let us know if you still meet the issue after disable the 2 options.
Helen
Helen Chen
