Global attributes not displaying correctly in PCB Editor -- Eagle 9.1.0
scott
scott
Suddenly, with the release of 9.1.0, global attributes are not being resolved in the PCB Editor.  For instance, I have an attribute called PCB_DATE.  In text strings I have >PCB_DATE.  Let's say the value of the attribute is 7/12/2018; that's what should display, and always has before.  Now I'm seeing >PCB_DATE instead.  When I right-click on the string, 7/12/2018 appears overlaid on >PCB_DATE for as long as I hold down the mouse button, but not permanently.  Is there some new setting I'm not aware of, or is this a bug?  Global attributes still work fine in the Schematic Editor.
Scott
jorge_garcia
Hi @scott,
I hope you're doing well. This is a known bug, it's been reported and the developers are working on it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
scott
Version 9.1.1, just released, doesn't fix this.
jorge_garcia
Hi @scott,
Still working on it, stay tuned.
Best Regards,
Jorge Garcia
